Hi All,
Im fairly new to creating revit families. I have a building that has pre fab metal panel cladding all around the building.
Ive created and attatched the family, its simple for now, just steel structure holding a profile made to look like steel decking, hosted on a wall.
I had to create the profile for the metal panel in a side elevation, and i cant figure out how to lock it to reference plans to adjust the width (front elevation or plan). How would i do this?
As well, im looking to have it so its a fixed distance below the level its inserted on. Say insterted at level 3, the base is actually 2 meters below level 3. I dont want to place it and offset in the model, i would rather have it automatically set up so its in the correct place showing the level with a zero offset.
Any help is greatly appreciated, thanks!
Solved by constantin.stroescu. Go to Solution.
you have doubled the side Reference Planes...and the element was not aligned and locked...
Constantin Stroescu
Perfect, i did not know how to get the lock/unlock symbol to appear. Thanks for the help!
