Locking extrusions to reference planes?
2 REPLIES 2
blawlor
4681 Views, 2 Replies
Hi All,
Im fairly new to creating revit families. I have a building that has pre fab metal panel cladding all around the building.
Ive created and attatched the family, its simple for now, just steel structure holding a profile made to look like steel decking, hosted on a wall.
I had to create the profile for the metal panel in a side elevation, and i cant figure out how to lock it to reference plans to adjust the width (front elevation or plan). How would i do this?
As well, im looking to have it so its a fixed distance below the level its inserted on. Say insterted at level 3, the base is actually 2 meters below level 3. I dont want to place it and offset in the model, i would rather have it automatically set up so its in the correct place showing the level with a zero offset.
Any help is greatly appreciated, thanks!
2 REPLIES 2
you have doubled the side Reference Planes...and the element was not aligned and locked...
Constantin Stroescu
BIM Manager AGD
Your Name
Perfect, i did not know how to get the lock/unlock symbol to appear. Thanks for the help!
