I am wondering if anyone knows a way to lock a dimension to a minimum. As an example, you need 18" minimum on a pull side of an accessible door. Obviously, this dimension can be 24" or any other number 18" or greater. If I wanted the hinge side of the door to be locked at 6" from the wall, and then the other side can only be >=18". Possible?
Thanks.
