Locked or Pinned items, Can they change color?
2 REPLIES 2
Jason_S
522 Views, 2 Replies
I am training some new hires and was asked this question;  "Can the locked or pinned items be changed to a different color so you can tell they are locked or pinned before clicking on them?"
I never have been asked that before and can't seem to find away to have items that are locked or pinned be a different color so they stand out as being locked or pinned.  Anyone know of away to do that?  I like the idea.
Thanks for the help.
2 REPLIES 2
SteveKStafford
in reply to: Jason_S
Not through Revit as delivered to us, someone using the API could probably accomplish it though.
My other older self here: http://forums.autodesk.com/t5/user/viewprofilepage/user-id/46056
One way of doing this, if you really want it, would be to create a project parameter, applied to all categorys named something like "Lock/Pin" and make it a yes/no parameter.
This method is no way ideal, and only really works well from the start of a project. But you can tick the yes box if you lock or pin an object as you are working. And you can apply a view filter for the specific view, looking to whatever categorys you want for the "lock/Pin" parameter.
But this is not very efficent and is a manual process. So unless, as mentioned above, you know about API mods then i would just leave it alone.
Alisder Brown
Senior BIM Coordinator
Scotland, UK
