I am working on a truss family, partially for the truss, and also to try to understand how to, and what to lock to in families. Can anyone give me guidance on how I would lock the Reference Line highlighted in orange to the mid-point of the Reference Line highlighted in blue (point #1). Also, I was having an issue with the peak at point #2 moving around. How would I lock the Reference Lines coming into this point at the peak? My file’s attached if you want to take a look. Thanks!
Solved by L.Maas. Go to Solution.
Have you looked in the revit libraries? There are several trusses in there. In the UK library for example you have the "Scissors Truss-4 Panel.rfa" which should be good guidance for what you want. If you do not have the UK libnrary installed you can also find it on seek.autodesk.com.
For point 1:
If you check you will see it is matter of additional reference planes with some EQ dimensions.
For point 2:
It might help to temporarlily hide lines which are might cause wrong snap points
In the screenshot hereunder I have temp hidden several of the reference lines.
Then used the align tool, selected one of the reference planes and then used the tab key on the reference line until the endpoint shows up (blue dot).
Then you can lock it to the axis. Repeat the process for the second axis.
As a side note. If you check the trusses from the library you can see that they do not use that many reference lines and use specila lines for the chords and webs
Louis
Please mention Revit version, especially when uploading Revit files.
