Locate and delete identical instances in a project?
10 REPLIES 10
Message 1 of 11
cemberger
10510 Views, 10 Replies
If you wanted to locate and delete identical instances, not knowing if there are actually identical instances only concerned that there may be some double counting in your schedules, how would you do it?
10 REPLIES 10
Message 2 of 11
vector2
in reply to: cemberger
Right click any view>"Select All Instances">"In Entire Project">Delete.
Message 3 of 11
cemberger
in reply to: vector2
We found that through the "Manage" ribbon and the "Warnings" tool, we could locate the duplicates.  It's not a very efficient process but it allow us to retain the original.
The process of selecting all instances deletes both the original and the duplicate, correct?
Message 4 of 11
Joe.Charpentier
cemberger,
Yes you are correct, the best way to do this is through the "Review Warnings" dialog under the manage tab.
DO NOT follow vector2's advice.  Doing this will delete every element of that type from the entire project.
I suppose your duplicate problem would be gone, though. Smiley Wink
I think the key here is that you are looking to remove elements that are identical and *coincident*.
If Revit does detect these , they will be shown in the  "Review Warnings" dialog.
Another reason (and way) to try to keep your number of warnings low.
Joe
Message 5 of 11
Alfredo_Medina
If you follow this advice, trying to delete, for example, a duplicated column, all the columns of the same type in the whole project will be deleted.  Total collapse.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
Message 6 of 11
vector2
@cemberger wrote:
delete identical instances, how would you do it?
Right click the element you want to delete all identical instances
for and click all instances and push the delete key.
All identical instances will be deleted.
How is this not so?
Message 7 of 11
CoreyDaun
What he is referring to is "duplicate" instances. For instance, if there are three copies of the same column in the exact same place, he only wants to delete two of them.
Message 8 of 11
vector2
in reply to: CoreyDaun
Thanks CADastrophe, but I don't see how you would assume,
"concerned that there may be some double counting in your schedules",
would translate into meaning, "three copies of the same column in the
exact same place, he only wants to delete two of them".
And why would you assume they only want to delete "two" of WHAT?
Seems like they just want to know how to delete all instances, wasn't
that the question? Being concerned about how this might affect a schedule
was not the question. For that they can delete all instances and then SEE
how affects the schedule.
Message 9 of 11
CoreyDaun
In the subject line, he wrote "Locate and delete identical instances in project?"
In my interpretation, if he wanted to delete ALL of them, he wouldn't need to locate them, or he wouldn't be concerned about identical instances either. His title would have been "Delete all instances in project" otherwise.
Don't get me wrong - I'm not saying your take isn't understandable. This is the great thing about so many people looking at the same problem, as anything can (and likely will) be understood different by each person. All the angles and bases are covered by different minds.
Message 10 of 11
vector2
10-4 CAD.
Message 11 of 11
GokhanKeskin
You can create a schedule for the items in question and sort it in accordance with the location mark or similar parameter.
