Loadlibrary failed with error 126: The specified module could not be found.
9 REPLIES 9
Message 1 of 10
15628 Views, 9 Replies
this message appears everytime i try to load a different type of door or window, then crashes all together. as far as i know its not a hardware issue, i use catalyts version 9.1 i have tried to repair and reinstal revit but nothing works if this question is somewhere else post it please.
Thanks, J
9 REPLIES 9
Message 2 of 10
ryan.duell
This error is most commonly reported [across a number of applications] related to an ATI driver or OpenGL conflict.
1.  I would ensure to upgrade to the latest certified driver from the download list below:
http://usa.autodesk.com/adsk/servlet/cert?siteID=123112&id=16391880
2.  If the issue persists, ensure Revit Hardware Acceleration is disabled, under Options > Graphics.  Close \ re-open Revit, and see if the behavior persists.
3.  Also, try ending any ATI Control Panel or similar applications running.
Thank you,
Ryan Duell
Message 3 of 10
my computer is brand new, an expencive acer, dosent that come with the  the latest certified driver ? can i download a driver for free ?
i have ensured that Revit Hardware Acceleration is disabled, but it dident help
i dont think i have any ATI Control Panel or similar applications running.
Message 4 of 10
I have the Same Issue with a new Acer that has Amd HD 7670M display adapter
Message 5 of 10
I've got the same problem.  Also with a new ACER laptop. Any answers on how to fix this yet?
Message 6 of 10
civilfx
Not sure if you have found a solution.  I have the same laptop with the AMD Radeon HD 7670M video card. I found the following link in which you can download a .reg file that will fix this error.  Don't ask me why, but the solution worked on my laptop.
http://www.withinwindows.com/2012/03/31/loadlibrary-failed-with-error-126-redux/
I have also attached the .reg file for your use (Change the extention from .txt to .reg).  Good luck!
Message 7 of 10
in reply to: civilfx
Thanks fixed mine too E-mail originating from AstenJohnson E-mail Services.
Message 8 of 10
The attachment worked
(I never download random file but I was desperate and it worked out in the end)
Message 9 of 10
It realy work! Smiley Very Happy
Message 10 of 10
Wow in 2015 it's still a working solution, thanks for saving me from having to uninstall the latest video driver, and trying to figure out which previous version works. How the hell did you come up with this? So simple.... Thanks again
