this message appears everytime i try to load a different type of door or window, then crashes all together. as far as i know its not a hardware issue, i use catalyts version 9.1 i have tried to repair and reinstal revit but nothing works if this question is somewhere else post it please.
Thanks, J
This error is most commonly reported [across a number of applications] related to an ATI driver or OpenGL conflict.
1. I would ensure to upgrade to the latest certified driver from the download list below:
http://usa.autodesk.com/adsk/servlet/cert?siteID=123112&id=16391880
2. If the issue persists, ensure Revit Hardware Acceleration is disabled, under Options > Graphics. Close \ re-open Revit, and see if the behavior persists.
3. Also, try ending any ATI Control Panel or similar applications running.
Thank you,
my computer is brand new, an expencive acer, dosent that come with the the latest certified driver ? can i download a driver for free ?
i have ensured that Revit Hardware Acceleration is disabled, but it dident help
i dont think i have any ATI Control Panel or similar applications running.
Not sure if you have found a solution. I have the same laptop with the AMD Radeon HD 7670M video card. I found the following link in which you can download a .reg file that will fix this error. Don't ask me why, but the solution worked on my laptop.
http://www.withinwindows.com/2012/03/31/loadlibrary-failed-with-error-126-redux/
I have also attached the .reg file for your use (Change the extention from .txt to .reg). Good luck!
