load hatch patterns into title block family
1 REPLY 1
730 Views, 1 Reply
Is there a fast way to load hatches into a title block family?
Tags (2)
1 REPLY 1
loboarch
In Revit they are called fill patterns, and they are created the same in a titleblock family as they are in a project.  Simple linework patterns can be created in Revit without an import.  If you need somethign else a standard PAT file can be used.
There is an add on to Revit called Hatch-22 that can be used to help you create a custom PAT file which can be used to create custom Revit fill patterns.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
