Yes very much LIVE. You should try it. Open a new project and draw a wall
with a door in it. Create a door schedule. On the Window pulldown menu
select Tile, so you can see the floor plan and door schedule at the same
time. Then copy the door or add a new one and you'll see the door schedule
update automatically. In fact in the door schedule change the door width
and you'll see the door in the floor plan change size. You can actually
modify your building elements through the door schedule. Real frackin nice,
huh.
wrote in message news:5502466@discussion.autodesk.com...
I am starting to get familiar with REVIT. Can someone please clarify if
REVIT is able to maintain schedules "live" (4d) in the plans? I am speaking
about Door, window, room finish schedules, etc... In other words, once the
schedules are generated, do they stay embedded in the plans and update
automatically without having to generate them again as building design
changes? (new doors are added, dimensions change, room finishes change,
etc...)..and without having to update the links of these schedules.... How
about "live" quantity take offs and estimates? How about "live" drawing
extractions? Are they possible in REVIT. I emphasize that what i mean by
Live is totally automatic, no work at all to update the schedules as work
progresses...
TIA,
Al
