Hi all,
I'm new to Revit but i'm struggling with a linked DGN file. When i link the file into Revit, the drawing won't be straight, instead would rotate clockwise about 45 degree. After i rotate the drawing back in position, Revit complains about slightly off axis when i do my grid lines or trace over the drawing?
What i'm missing?
Thank you....
Solved by ennujozlagam. Go to Solution.
hi, im not familiar with mircostation dgn file and havent try yet linked to revit, but in autocad what you see in autocad, what you get in revit once you link the files. it shouldnt happenned that way?
try to start a fresh file and link again. please see attached. hope it helps.
@ennujozlagam wrote:hi, im not familiar with mircostation dgn file and havent try yet linked to revit, but in autocad what you see in autocad, what you get in revit once you link the files. it shouldnt happenned that way?
Thank you for your reply.
I tried many times with DGN and DWG but same problem. I played with the settings you attached but no help!
I will attach a photo of the issue just so you can see what i'm dealing with....
Please see attachments....
I converted DGN -> DWG and linked to revit, when i did that i received the message showing on attachment "Revit Message.PNG"!!
Thanks.
Thanks.
Update with regards to the attached Revit message when linking CAD. Problem solved, all i had to do is open the dwg in autocad, clean it up and use WBLCOK.
I still need help with CAD not showing straight as per attached image.
hi try this,
xtents Greater than 20 Miles
Can you please private message me your email address so i can email you the CAD file.
thanks, I managed to help you.
If this helped solve your issue - remember to 'accept as solution' to help other find answers!!!!!....shalom……….
