In Revit Architecture 2011 I have imported a manufacturers detail into a drafting view. How do I control the lineweights in the detail? There is no "Import/Export Settings" in the File pull down and I can't find it anywhere else.
Lysle
You can control display of linked dwgs in the Visibility / Graphics Override for the view, or by the Object Styles controls. Select the tab for Imported Families, and you will see the dwg, and can make changes by layer.
bt
Thank you,
This was also answered in another thread. I'm including a link to the other thread since it also has info on how to set default lineweights before the DWG is imported.
Lysle
