lines missing
1 REPLY 1
nikki
159 Views, 1 Reply
lines missing
I drew some 2nd lines in my second floor plan and I was able to see them. But now they don't seem to be there. I can see them when I select them but its like they're invisible. And when i underlay that floor in my first floor I can see them. I also checked the visibility parameters, and the lines family is on! I feel so frustrated not resolving something I'm sure is a simple solution. Please help! thanks.
1 REPLY 1
in reply to: nikki
You drew model lines, yes? Model lines exist on a surface. Something is above the lines (such as your floor) and hiding the lines. Sounds like you should have been using detail lines which are always on top and view specific. "nikki" wrote in message news:22832122.1100111099559.JavaMail.jive@jiveforum2.autodesk.com... > I drew some 2nd lines in my second floor plan and I was able to see them. But now they don't seem to be there. I can see them when I select them but its like they're invisible. And when i underlay that floor in my first floor I can see them. I also checked the visibility parameters, and the lines family is on! I feel so frustrated not resolving something I'm sure is a simple solution. Please help! thanks.
