I'm working on a model in which the windows and curtain walling seem to be ignoring the hidden line settings in all elevations and sections - see attached file.
If I copy and paste elements into a new file they display fine. If I link the file into a new file, everything displays fine. All other element types seem to be hiding correctly.
I've applied previously created (and working) view templates and they make no difference.
Running out of ideas here as to what might be causing the problem. It's come at an awkward time as we are just getting ready to release GA's...
Anyone got any ideas?
Cheers
K.
Solved by Keith_Wilkinson. Go to Solution.
Okay. After playing around with a few backups and a stripped down file that was uploaded to the rest of the project team last week I've established that the problem is somehow related to the DWG files that are linked to the file.
Weirdly though it doesn't seem to be any one file in particular as unloading or removing them in differing sequences resolves the problem at different stages.
ITS ALL A BIT WEIRD.
Anyway, at least for now I can continue working with the model as is as ultimately the DWG's will be removed and for the moment unloading them seems to resolve the issue.
If anyone else comes across something similar let me know and if anyone has any ideas as to what the underlying issue is here I'd love to know.
cheers
K.
