Thin, Medium, and Wide plot to thickness 1, 3, and 5.(by default) These are
settings in Settings>Line Styles
Defining what 1,3, and 5 weights are at different scales is defined in
Settings> Line Weights
wrote in message news:4843189@discussion.autodesk.com...
when using detail lines and you choose thin lines medium lines and wide
lines, is there a way to tell the actual thickness of these lines when
plotted.
is there a way to assign a specific line weights to these lines based on the
drawing scale
thanks
