Have you looked into Settings>Line Weights? This controls the thickness of
line "weights" 1 through 16, for every scale view, and for model objects,
annotatins, and perspective views.
The you use Object Styles to assign a Weight 1 to 16 to the individual
objects projection and cut styles.
"John Gray" wrote in message
news:5240393@discussion.autodesk.com...
I'm beginning to plot things out onmy first project and i'm noticing
lineweights are WAY WAY to heavy. I have some building sections that are at
1/4" and the "cut" lineweight is so heavy that the line work just runs
together and makes everything look extremely thick. Is there anything that
state at what scale a certain detail level should be used? Also is there a
way to globally scale down the line weights? It seems in general the
lineweights are to heavy in all my views, i like how they do step down in
sections and stuff but they are just to heavy. What is my best way to go
about controlling lineweights...???
Thanks everyone,
John Gray
