I seem to be having a bit of an issue with some lines showing up in color. I am sure it is a setting in a window somewhere, however, I cannot figure out which one. I exported my plan to an autocad drawing then imported it back into an annotation family to use as a key plan. I could not find anyplace to change all of the colored lines to black in the family, but I did change them in the project in the object styles window. My issue is that some lines still show as green or beige. I have concluded that it seems to be all of the dashed lines-minus the ones for the skylight (those changed to black). Any idea on where this menu is that would allow me to change those few remaining lines to black?
Solved by cjp. Go to Solution.
Solved by rosskirby. Go to Solution.
Manage --> Object Styles --> Imported Objects, then click the "+" next to the name of the imported DWG, shift-select all the layers, click on the sample button under "Line Color" and choose black from the palette.
Alternatively, re-import the CAD and choose "Black and White" instead of "Preserve Colors".
Another alternative, screen cap a view of the floor plan and put it in your titleblock. If you've got more than one key plan, just insert it on the sheet itself, rather than the titleblock.
I did change the object styles at one point and was unsuccessful. I went back and reimported it as a black and white CAD drawing and that did what I needed it to. Thanks.
