I have managed to replicate a youtube tutorial on creating a parametric array, however when the component is loaded in a project, and the "joist length" is increased, the array breaks apart.
Can I get some help on this one please
RVT file attached.
Solved by CoreyDaun. Go to Solution.
Solved by BIMAbhi. Go to Solution.
When you creating the parametric array with the help of the option (2nd or Last option) please align the First Object and Second objetct (2nd Option) or First object and Last Object (Last Option) vertically. After doing you can put the array number.
Don't beleve this formula is working correctly though.
I want my max centers to be no more than 600mm, however when I dimension the array family, it's showing to be larger than 600, how to I fix that?
Try simply adding a ROUNDUP function to the "Stile Count" formula, and see if that solves your issue.
= roundup(Divisible Length / Max Spacing)
Your formula for "Joist Count" is missing the roundup function; revise as per the formula below:
If this is a family for joist layout you might consider using the beam system tool Instead of a line based array. The beam system is already setup to do this kind of thing and you just tell it what structural member you want to use in the beam system. It might be more flexible in some situations too. For example you can change the edge condition or cut an opening in the beam system and the "beams" will adjust to the boundary.
If it was me I would still consider a beam system and manually place the members at the start and beginning when required.
