Thank you very much, I corrected this and now it looks ok!
I must say that these two things should work together...
Ï "sdbrown" Ýãñáøå óôï ìÞíõìá
news:7146673.1095684257569.JavaMail.jive@jiveforum2.autodesk.com...
> the accurender material doesn't sync up with the hatch pattern they are 2
totaly sep. things.
> So you have to adjust the accurender materials offset within the material
editor, try from your image to guess how far off it is and then input that
into the material properies, ie. x =.5 and y= .25 note that the units in
the material editor are in decimal feet.
