lighting fixtures on electrical plan
2 REPLIES 2
nikki
390 Views, 2 Replies
Our company's usual standard is to show the electrical and the lighting fixture layout on the same sheet, is there a way to do this in revit? I noticed that the light fixtures will only snap when inserted into the ceiling plan and not the electrical plan. Help, thank you.
2 REPLIES 2
in reply to: nikki
On the sheet, overlay the electrical floor plan and the electrical reflected ceiling plan. They will snap to each other for placements, then just turn off one view title. "nikki" wrote in message news:18927432.1100033131097.JavaMail.jive@jiveforum2.autodesk.com... > Our company's usual standard is to show the electrical and the lighting fixture layout on the same sheet, is there a way to do this in revit? I noticed that the light fixtures will only snap when inserted into the ceiling plan and not the electrical plan. Help, thank you.
nikki
in reply to: nikki
sounds good, thanks!
