Life to Existing Phase Materials
2 REPLIES 2
2519 Views, 2 Replies
I am having trouble having objects set to 'Phase Created' = Existing to show a desired material.  They are all a dark grey.
I have gone into 'Manage', and "Phases" under 'Phasing', and under the tab, 'Graphic Overrides', changed 'Material' for 'Existing to "Phase - New".  But this did not change anything.  (see attached photos)
Where else does this get changed?
/ Using 2013
2 REPLIES 2
In the Phases graphics change the existing material to none or by category. This will get rid of the material override set by the phase and preserve the materials you have assigned to walls, etc. Ricardo Twitter: @rmaturana
Great! Thank you Ricardo.
I wasn't able to find, "by catagory" or "none", but found "No Material" which only seems to exist in this scenario.  (I'll post it for the benefit of others.)
