I am having trouble having objects set to 'Phase Created' = Existing to show a desired material. They are all a dark grey.
I have gone into 'Manage', and "Phases" under 'Phasing', and under the tab, 'Graphic Overrides', changed 'Material' for 'Existing to "Phase - New". But this did not change anything. (see attached photos)
Where else does this get changed?
/ Using 2013
Great! Thank you Ricardo.
I wasn't able to find, "by catagory" or "none", but found "No Material" which only seems to exist in this scenario. (I'll post it for the benefit of others.)
