License Transfer Utilisty Error 41
1 REPLY 1
1204 Views, 1 Reply
Hi! today I uninstall my revit 2013, to fix some problems I had, so before that I exported my license with the LTU. The problem came, when I reinstalled the program and tried to use the LTU to import the license. It showed me a message saying there was an "error 41"
I dont know why did that happend, because when I uploaded my license it was successufylly made.
1 REPLY 1
TravisNave
The LTU is often problematic.  I would recommend simply trying to activate the license again on your new computer.  You might have better luck.  If it won't activate, you can contact Autodesk Activations for help.
You can use the online method to activate your license here:
http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
