Solved by fredrik. Go to Solution.
Solved by CoreyDaun. Go to Solution.
Solved by DanePower8891. Go to Solution.
I had this issue when working off a template with a different massing and elevation, it threw the levels off.
Revit seems to crop the levels in 2D space depending on your view settings.
-To fix this I had to go to the 3D view and locate and move each level line closer to the object. In turn, each level line showed up on every view as it should.
In addition to this topic:
If levels ar in a scope box in a linked file, they will not be show in a section in your project. I had to copy(/monitor) them from a 3d view, and then set the scope box to none.
I tried all of the above and nothing worked. What finally worked for me was:
After I did that, all of the "missing" levels suddenly appeared.
