Solved by fredrik. Go to Solution.
Solved by CoreyDaun. Go to Solution.
Solved by DanePower8891. Go to Solution.
Jeff,
I have to click on each level individually in each view and un-check "maximize 3D extents". I try and select them all that option does not appear on the screen. Is there another way apply this setting by selecting all levels in the view? Thanks.
Hi there,
When i create new levels, they appear in plan views but are not seen in any of the elevation views. Can anybody help me out on this......??
Thanks in advance...
Hi I am currently working on a project and i created a land plot and set each level line to the proper elevation but not all of the level lines appear in every view. In the North view all of the level lines and the walls i have created appear, but the walls don't show up in any of the other views. Also the North, West, and South views show all of the level lines but the East view does not. How can i fix this? Thank you
Some of the levels are not showing up in section or in the elevations. Please assist
Open a Section or Elevation that does show the Levels, or create a new Elevation View and turn off Crop View and set Depth Clipping to "No Clip". The Level must actually enter the boundary box for the Section or Elevation in order to show up in it. Go to a perpendicular Elevation View that shows all of the Levels and adjust the ends of the Level lines as required. See image below.
Just adding my two bits too. I had levels set up and assigned a scope box to them. I then created several elevations for my shearwalls, and assigned a template to them. The Levels weren't showing in the elevations. Turning off "Crop View" and then turning it back on worked. (Small bug?) Revit 2015.
Hi I wrote a little tutorial on this a while back, thought it might be helpful: http://essentialbim.com/2014/01/09/how-to-always-view-levels-in-revit-regardless-of-your-sections-ra...
Easiest way to select all levels is to left click on a any level in view, then right click go to "select all instances" then "in entire project" left click. Then Right click again on one of the now highlighted levels, then left click on "maximise 3D Extents". This should hopefully solve all level viewing problems.
Do note that as you expand and work on the model and start building in other areas, you may need to do this again to cover the new larger model.
This issue has happened to me before. If I link a Survey and it isn't centered close to the default Elevation Tags in Plan, everything else gets wacky.
If I move the Elevation Tags to fit the Survey location, this causes trouble. But the Survey is located to some marker in "reality".
The solution is as Jeff stated, right click an Elevation Tag and then Zoom To 3D Extents.
If I move the Survey to where in the center of the Elevation Tags, the problem doesn't happen. I just have to Publish Coordinates in this location.
But I'm thinking the best solution is to leave the Survey .dwg alone and move the Tags around.
Thanks for the thread, in any event. Cheers.
