The problem is likely that since Level Lines are not infinite, your
elevations/sections do not pick them up. If you can see them in one view,
but not others, you can select the level and hit "propogate extents", that
should expand the level through the model. If you can't find them at all,
create an elevation view way off in the distance (you might have to do it in
two directions), with the extents much larger than the model itself, and no
far clip. You might be able to see the levels way off to the side of the
model, and can drag them back over (make sure you drag the 3d ends, not 2d)
or propogate extents.
"Blake Middleton" wrote in message
news:5147998@discussion.autodesk.com...
I have the same problem with some level lines not displaying in some
sections, but are in others.
"discussion.autodesk.com" wrote in message
news:5147967@discussion.autodesk.com...
Hi All,
In a practice project I deleted all of my elevation views but not the
levels. When I created new elevation views the existing level datum lines
do not show up. When I try to create replacement level lines I cannot label
them the same as existing levels. I understand why I cannot rename them but
is there a way to turn the existing level datum lines back on or can I
create a new level then associate it back to an existing level?
Thanks in advance,
Tom
