Revit Architecture
Revit Architecture
Distinguished Contributor
Barryfisher
Message 1 of 6 (411 Views)
Level Not Showing in Section
411 Views, 5 Replies
08-02-2012 07:46 AM
Hi Guys
I've got a model and i created a new level as normal, propogated extents etc but when i created as section North to South (Vertical) in the model the level does not show. When i create a section from East to west (horizontal) then the level appears fine. I've tried creating many sections and this is always the case. If i select a level in the section and click on select all instances in entire project the number includes the additional level but i can't see it. It is not hidden in the view, not on a different workset or anything unusual...
Any thoughts
Cheers Barry
ccollins
Message 2 of 6 (409 Views)
Re: Level Not Showing in Section
08-02-2012 07:51 AM in reply to: Barryfisher
Try uncropping/cropping the view. In View Properties of the Section, try using Crop with Line, Crop without Line, change Far Clipping, etc.
Can you see this Level in other views?
Turn off crop region, then Zoom extents--perhaps the Level lines are far away--then click 2d extents and drag back into the view area.
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
Barryfisher
Message 3 of 6 (404 Views)
08-02-2012 08:29 AM in reply to: ccollins
Cheers
tried all that and made no difference at all.
It's funny that if i take a section in the N/S direction then the section does not show the level but if i take one in the E/W direction then all is fine....
It's not one i've hed before...
ccollins
Message 4 of 6 (390 Views)
08-02-2012 12:10 PM in reply to: Barryfisher
Design Options? Phases? Filters?
Try re-creating the view (another section in the same direction.) Do the Levels show up?
Cliff B. Collins
St. Louis, MO
parveen.revit
Message 5 of 6 (377 Views)
08-03-2012 12:25 AM in reply to: ccollins
also try reveal hidden  elements button.
Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
Active Member
JohnCubed
Message 6 of 6 (163 Views)
07-15-2013 03:33 PM in reply to: Barryfisher
Go to the section or elevation view in question. Under Properties go to 'Extents'>Far Clipping>set to 'No clip'
