It is almost seeming like you should not try to creat these views in templates to get a jump start on projects. but for the life of me I am not understanding how you can get level lines to appear elevations that have already been create. or in new ones?
is there away to successfully get these back?
So - just to make sure i understand.... You have a template file that you have created levels in. WHen you create a new elevation view - those levels are not visible?
A few thoughts...
The levels are turned off in the view - go to VV, annotation tab and turn levels on.
Is the crop region cropping the other levels out so youdon't see them?
Check those and let us know what you find...
LD
They were on, but I hit a view template and got them back, not really sure waht I did but I think I got it. it happen so fast.
I was trying to figure this and true north out at the same time.
but one other question I got regarding this is how to change level heights for the project with out moving the building
instead of 0'0" on level one, I want to start it off with 100'0"
See my response to this post:
It is basically the exact same answer for your question about level lines.
