Level 2 doors showing up on level 1 door schedule
6 REPLIES 6
clr4tkoff
879 Views, 6 Replies
Hello - I am having a little trouble with some doors showing up on the level 1 door schedule that are actually on level 2. They are curtain wall doors. I can't seem to figure out why this is happening - can anyone help?
Thank you!
LD
Kalamazoo, MI
6 REPLIES 6
in reply to: clr4tkoff
do they intrude into level 1 at all? are they mounted below level 2? are they actually located on level 2, or just "physically" on level 2?
its because your curtain wall is probably on the 1 st level. If you want CW door to show accordingly, you ned to break down the CW
clr4tkoff
as far as i can tell they do not intrude on to level 1. they are not mounted below level 2, they are located on level 2.
clr4tkoff
our building is a split level so this specific curtain wall is on leve 2 only.
Can you post the file (or part of it )
DMartin80
I know this is quite some time on from this discussion, but I have just had the same issue. A work around for this problem is to change your filter parameters in your schedule to arrange by Mark numbers instead of by level - that is assuming that your unique door numbers contain specific letters/numbers indicating the level they occur on.
