Welcome to Autodeskā€™s Revit Architecture Forums. Share your knowledge, ask questions, and explore popular Revit Architecture topics.
Showing results forĀ
Did you mean:Ā
length of the beam ?
2 REPLIES 2
jeevanjacob
600 Views, 2 Replies
I have all my columns in position. I need to draw the beams. Should I use center to center or edge to edge?
I tried it in both ways. Both gave same volume but different lengths in properties palette.
jeevan
2 REPLIES 2
ccollins
in reply to: jeevanjacob
There is a beam "cut back length" that allows for connection plates, etc.
Take a look in the beam family properties.
Typically, beams are placed from center to center of columns, and the cut-back length automatically pulls the ends away
the specified dimension.
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
jeevanjacob
in reply to: ccollins
Hi Collins,
Thank you.
May I rephrase my question? I need to export the structural frame, for analysis, to STAAD. For the purpose, center to center is the right method. But as I inserted all my beams, using grid option in the toolbar, I got edge to edge only. Is there a method to overcome this (other than rearranging each and every beam)?
regards
jeevan
