With the building higher and higher, wind feels increasing presure. Autodesk, do you feel presure high? No, as you know, by means of an add-in and several parameters, twisting wind into nothing is so easy.
See demo video at: poprevit's channel
The new ocos2013 version is released.
You are welcome to test the free add-in ocos2010. Don't forget, the Autodesk Revit 2010 is a classic version forever.
"Revit 2010 is a classic version forever"
Actually you mean 2011, whether you know it or not.
Yes 2010 was the finished conversion of the program from
the original, (basically 32 bit to 64 bit), completely rebuilt by
Autodesk, just like Windows Vista was the new 64 bit Windows.
But as we all know, that historic transition to 64 bit Windows,
with Vista, was not really ready for prime time. Same with
Revit 2010. Like that first version of the ribbon, it was not so
good, but the ribbon for 2011 was very good, and will basically
be the same for many future releases. 2011 has a very stable
foundation, just like Windows 7. But nearly anywhere you reside
in the BIM chain, you need the current release.
Thank you for your attention. The thing is different criteria. From simple, stable, and easy to use, the 2010 is classic, from bulk of theories, the 2011 is better.
