Show only
Search instead for
I have imported a Kohler DWG file into Revit.
PROBLEM:
All of the whirlpool tube jets are 90 degrees to the surface of the tub.
This is not the case when I open the file in ADT 3.0.
Any Solutions?
Doug
Are the jets a block with non-uniform scaling or have they been mirrored in
AutoCAD? AutoCAD can do some strange things with the UCS that affects import
into other projrams.
"Doug" wrote in message
news:400d28a5$1_2@newsprd01...
> PROBLEM:
> Any Solutions?
> Doug
Just a thought, but there are quite a few Kohler based families on www.rugi.org Have you checked them out? If not, what you want might already be there?
