Kohler Tubs
2 REPLIES 2
544 Views, 2 Replies
Kohler Tubs
I have imported a Kohler DWG file into Revit. PROBLEM: All of the whirlpool tube jets are 90 degrees to the surface of the tub. This is not the case when I open the file in ADT 3.0. Any Solutions? Doug
2 REPLIES 2
Are the jets a block with non-uniform scaling or have they been mirrored in AutoCAD? AutoCAD can do some strange things with the UCS that affects import into other projrams. "Doug" wrote in message news:400d28a5$1_2@newsprd01... > I have imported a Kohler DWG file into Revit. > PROBLEM: > All of the whirlpool tube jets are 90 degrees to the surface of the tub. > This is not the case when I open the file in ADT 3.0. > > Any Solutions? > > Doug > >
Steve_Stafford
Just a thought, but there are quite a few Kohler based families on www.rugi.org Have you checked them out? If not, what you want might already be there?
