Keynote Generated List in Revit 8.1
1 REPLY 1
2j2mattones
206 Views, 1 Reply
I'm running Revit 8.1 at work, & now that I've gotten the Keynotes set up and are viewing relatively properly, i want to fine tune my knowledge of keynoting for the future. The issue I'm running into when I use Note Blocks for keynoting is when I have multiples of the same keynote it will generate multiple instances of that particular note in the list. What I did for the time being was just go to the properties of each keynote, and if it was a duplicate I simply left the Text & Tag portions blank. Even though this partly solves the issue of having duplicates on the generated list, it still generates an empty row in the list and it generates these empty rows on the top of the list. Preferably, is there any way to fill in the Text & Tag portions of the Keynotes & have multiples of specific keynotes but have only one instance appear on the list, or to "hide" the empty rows, or if there is some other way to accomplish what I am trying to do what might it be?
JM
1 REPLY 1
in reply to: 2j2mattones
Edit schedule, properties, Sort/Grouping make sure
the "itemize every instance" box is not checked.
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
I'm
Thanks, JM
