Keynote field in Windows Tag
1 REPLY 1
754 Views, 1 Reply
Is there a way to include Keynote field in at custom windows tag?
1 REPLY 1
Alfredo_Medina
Yes, it is possible. Since the Keynote parameter is not available as a default label, you need to create a text shared parameter, and include it in the window family. Then, this new parameter needs be set by formula as = Keynote
The shared parameter needs to be added to the Window tag. Also, it has to be added in the project as a project parameter for windows. After all that, the window tag will display the keynote value assigned to the window type.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
