We build our models in Sketchup. Export a 3d DWG and import that into Revit 2014 (through Conceptual mass). That way we can export sections etc from Revit.
The problem is that Revit sees the 3D DWG as a Mass, and therefore don export the layers we want to AutoCad.
Is there a way to "explode" the 3D DWG in Revit so it gets divided in to the layers we had before it was transformed into a Mass. So the layers follows the DWG export to Autocad?
Thanks you.D
