Hi - Could somebody give me some advice on joining roofs please.
I'm trying to join two roofs together by extending onto the other - Unfortunately the one to be extended is higher than the other roof (see attached image).
Both roofs are created by footprint.
Thanks in advance.
Steve Hole
Revit LT 2014
Solved by constantin.stroescu. Go to Solution.
I propose to make two Roof by Footprint using Cutoff Level:
Your Name
Thanks for the assist... Could have spent hours trying to figure that out...
Steve Hole
Revit LT 2014
