Joining Roofs - Higher Roof to Lower Roof
2 REPLIES 2
steve
3347 Views, 2 Replies
Hi - Could somebody give me some advice on joining roofs please.
I'm trying to join two roofs together by extending onto the other - Unfortunately the one to be extended is higher than the other roof (see attached image).
Both roofs are created by footprint.
Thanks in advance.
Steve Hole
Revit LT 2014
Steve Hole MCIAT
Chartered Architectural Technologist
3HW Architecture & Design
Helston, Cornwall, UK
2 REPLIES 2
constantin.stroescu
in reply to: steve
I propose to make two Roof by Footprint using Cutoff Level:
  1. First make in Floor Plan View a seria of Reference Planes to control the position of major volumes of the roof
  2. then , in an Elevation View or Section , place a new Level (Level 3) at a distance from Level 2 equal with the distance from roof 1 and 3 to roof 2
  3. using Roof by Footprint sketch roof 2 with two slopes - from Properties use Base Level 2 and Cutoff Level 3 - Image 01 and Image 02
  4. make a Roof by Footrint in Floor Plan - Level 3  without cutoff in top of the cuted roof from step 3 - as in Image 3 - the same slope angle as the roof from level 2 to 3
  5. the result is - Image 04
  6. Back to roof 2 - Edit sketch - increase the lentgh of it so to come under roof 1 and 2 - as in Image 05
  7. Now, Join the two roofs using :Geometry > Join Geometry
Constantin Stroescu
BIM Manager AGD
Your Name
steve
in reply to: constantin.stroescu
Thanks for the assist... Could have spent hours trying to figure that out...
Steve Hole
Revit LT 2014
Steve Hole MCIAT
