Revit Architecture
Active Member
rosbeh
Message 1 of 5 (303 Views)
Joining parapet cap
303 Views, 4 Replies
01-25-2013 05:12 AM
What is the matter with all new software? Nothing is simple. Here's another problem that cost me a lot of time and effort: I have made a wall with a parapet on top using sweeps. However, no matter how much I try I can't get these four walls to join their parapet caps together around the corners. All the other walls are ok. It's just these four. I've tried disjoining and joining the walls, pulling and dragging the walls and/ord the caps back and forth without success. Please explain to me why this even should be an issue????
Valued Mentor
mike
Message 2 of 5 (297 Views)
Re: Joining parapet cap
01-25-2013 05:36 AM in reply to: rosbeh
Where is the line locations for your walls?  I'd check them 1st......seen cases where if they where to the 'inside' of the wall some sweeps wouldn't work right......Also may want ot look at the Sweep Profile itself, and it's origin/orientation.
Mike
Michael L. Maloney
Virtual World Designs
VDC & BIM Model Design, Clash & Coordination
mike@VirtualWorldDesigns.com
Building Design Suite Ultimate 2013, 2014, 2015
Charlotte, NC ; Fort Mill, SC
ccollins
Message 3 of 5 (286 Views)
01-25-2013 06:01 AM in reply to: rosbeh
Try using the Wall Join Tool, and Miter the corners. Sometimes this cleans up the sweeps.
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
Active Member
rosbeh
Message 4 of 5 (285 Views)
01-25-2013 06:02 AM in reply to: rosbeh
As you can see, they are perfectly in line. As I said, the problem is not the profile itself, since sweeps using the same profile join perfectly elsewhere in the drawing.
ccollins
Message 5 of 5 (283 Views)
01-25-2013 06:06 AM in reply to: rosbeh
Perfectly in line, perhaps--but are the walls actually Mitered? ( versus butt join, etc. )
(a small but important factor with wall joins and the way sweeps behave.)
If mitering the walls does not fix the sweep joins, then it could be something wrong with the profile,
as mentioned in the other reply.
You can also try using Modify sweep returns.
Cliff B. Collins
St. Louis, MO
