hi, i want to join the 2 piece of timber on as it shows on the pic. the quesrios, how can i join it without having the end as it looks, i want to join it properly.
thanks
here is the link of the pic. http://screencast.com/t/QJyb8JhrCqn
Solved by subhra_civil. Go to Solution.
As per my understanding from your image file i have made a solution about your problem. Please find the attached image file. May be it can help you.
Thanks & regards,
Subhradeep Sen
Kolkata
India
hi, i checked and i don't have this option as you do.
here is the link of a pic. http://screencast.com/t/A1rjJSDHIuG7
thanks
Thanks for your reply.
I think you usuing Revit 2014 Architecture version. If you have all in one version Revit 2014 then you have not loaded option properly. You will be able to see it in Revit Structure. Use Revit Structure 2014. Otherwise go to Top Left > Click on Big "R" > Option > User interface > Configure > Click on Structure.
It will be loaded. Try to Grab it.
Thanks & regards,
Subhradeep Sen
Kolkata
India
hi, thanks for try to help me. i tryed what you asked me to do but what i get when i click on the big R is this.
here is the pic.http://screencast.com/t/mEeWYEEmq
thanks, if is posible could you do a small screen cast and show me, if not then i will have to download revit 2014 structure.
thanks.
Just Follow my two numbers image. I think it will be solved your problem.
Thanks & regards,
Subhradeep Sen
Kolkata
India
hi, i think that there is something wrong with my revit. i dont get your options.
look at this pic..http://screencast.com/t/rDLmPkEUD
thanks.
Thanks for your reply. Yeah, I think your Revit 2014 is not loaded properly. Only Revit Architectural is loaded. So that you will not be able to access any Structural or System option. Just Check it and reload it. When you will load Revit then you have to on the three option (Architecture, Structure & System). Then it will be loaded properly and work.
Thanks & regards,
Subhradeep Sen
Kolkata
India
thanks Sudha-civil
thanks MPWUZHERE.
So, wich revit do i have to install? the package that just says Revit, not revit architectural. or any other?
thanks.
well as Sudha-civil says, has to be the Revit one.
here is a pic of the one i will download. http://screencast.com/t/ocVC8MlHD
the REVIT one.
well the solucions was download Revit.
i got the options now as shown on the link. http://screencast.com/t/7naiuXWxJ1
and i got the join cutback option.http://screencast.com/t/gIOfWk7m
thanks Subha-civil and MPWUZHERE.
hi i have been looking and exploring the JOIN CUTBACCK, but i though that it was going to do the cut as i wanted, straight it shows on Sudha-civil pic also it just give me options in some of the timber, not in all of them, is there something that i can do about it?
here there is a video showing it. http://screencast.com/t/tAGs65kCBAbQ
thanks
