join roofs
6 REPLIES 6
hip36
173 Views, 6 Replies
join roofs
Anytime the front roof has a step that is hidden by a higher roof I am having trouble joining them together
6 REPLIES 6
hip36
in reply to: hip36
If I do get them joined I end up with unwanted lines
in reply to: hip36
Can you post the rvt file?
Paul Monsef
TSA architects, pllc
wrote in message news:4828442@discussion.autodesk.com...
hip36
in reply to: hip36
It has been quite a while since I worked on this one and I believe I may have messed pt up a little trying to make it work. I think only one ridge should show on the entry pop out mess and it should die into the hip smoothly. There is a hole concept that I am not catching here on how to split the main front roof with two different fascia positions and hide it behind the entry, a real common Florida style
hip36
in reply to: hip36
Not sure at what stage this is either I have recentltly caught on to the lineworks to hide the unwanted lines, but my roofs are still not really"right".
in reply to: hip36
The reason your entry roof doesn't appear to join with the main roof is that
it does not hit the hip in the right spot... Try cutting a section - left to
right - through your entry roof & dropping or raising the roof as necessary.
Also, I'd suggest making the roof outlines a little complicated until you
have the roof worked out. ie, get the massing done and right, and then edit
the footprint to be "right"...
Paul Monsef
wrote in message news:4831473@discussion.autodesk.com...
really"right".
hip36
in reply to: hip36
thanks I will try it
Rail Community
