I'm trying to Join First and Second Floor walls that are interrupted by floor framing.
I've separated sheathing and siding layers and extended these over to the lower wall.
All looks good, except for the joint line.
In section view, I use Join Geometry tool and it works, the joint is gone.
However on Elevation and 3D viiews the line is still there.
Any idea how to fix that?
Solved by constantin.stroescu. Go to Solution.
I had such a problem and a solved in two ways :
Method 1 is the best one ..
Your Name
Any Idea how to use the join geometry on these walls ? I can join walls that are in straight line but were the straight walls meets the curved one it wont work ?
Windows wont cut , and it also looks bad in elevation views (I've tried LW (invisible lines) in elevation and it also doesn't work))
