I joined a new masonry column into an existing masonry wall. Revit correctly
displays the new column cut into the existing wall in the new construction
view. In my existing construction view, the existing wall is cut out where
the column is located. The column doesn't show in the existing view which is
correct, but the cutout in the wall is not correct. Is this the way Revit is
supposed to work? I wouldn't expect so.
Arthur
