Hi all, is there any way you can join 2 objects together to make a corner, im trying to make a channel corner piece and cant seem to get the two objects to join. Does anyone have any idea how to do this?? find attached the family. Many thanks.
Solved by constantin.stroescu. Go to Solution.
I sugest using Sweep instead of Extrude , it is much appropriate in this case..
https://screencast.autodesk.com/main/details/527ab5ea-ab21-4f68-8f65-0bd06dcbe552
Your Name
