Italian language pack for Revit 2013
24 REPLIES 24
Message 1 of 25
andrea_pontiggia
8497 Views, 24 Replies
Hello, can you tell me when it's ready for the Italian language pack inserted in the version of Revit Building Design Suite Premium 2013? thanks
Andrea
24 REPLIES 24
Message 21 of 25
Hi
I did what you wrote. I also changed Revit.ini file to set proper language but nothing happened. What is funny:
"DefaultTemplate=Stavební šablona=C:\ProgramData\Autodesk\RVT 2013\Templates\France\Construction-DefaultFRAFRA.rte" ... this is a default path for Czech Template... France.
Gooood jooob.
Can somebody tell me if it realy works and what shoud I do to make it happen?
Thank you
Rudolf
Message 22 of 25
you should download proper language pack from subscription center, not from autodesk webpage. And check if it is for suite or architecture/structure/mep only.
Rudolf
Message 23 of 25
in reply to: Tony_Michniewicz
Hi!
I've this same problem with polish language pack for Building Designs, I install with your instruction but that still dont work!
Message 24 of 25
Could you provide more details regarding your problem installing the Polish language pack?  Is there an error message and when do you see the error message; during the install setup, at the end of the installation process or when attmepting to launch the product?  Hopefully with a bit more information, we can get the language pack installed and running on your system.
Tony Michniewicz
Autodesk Revit QA
Tony Michniewicz
Revit Software QA Analyst
Message 25 of 25
I would like to install Revit 2013 with Polish language pack.  I have Revit version  of Building Design Suite Premium 2013. I follow your instructions and it is still not possible to change to Polish. If someone managed install the language pack? Should not the appropriate language version appear here during the installation?
