journal in outlook
journal in outlook
Message 1 of 11
journal in outlook
so i am wondering can anyone look at this code and see if they can get it to
work? this is not my code this is from the www.autojournal.net web site. i
do not know anything about vba so please, i beg, do not give me explanations
on why is does not work since i will not able to do anything with it info
you provide.. thank you so much...
___________________________________________________
Option Explicit
Public WithEvents ACADApp As AcadApplication ' Use with Application Event
Examples
Public myolapp As Object
Public myitem As Object
Public SALARYMANOPEN As Boolean
Public DOCUMENTNAME As String
Public REGVAL As Variant
Public FN
Sub AcadStartup()
' This example intializes the public variable (ACADApp) which will be
used
' to intercept AcadApplication Events
' The VBA WithEvents statement makes it possible to intercept an generic
object
' with the events associated with that object.
' Before you will be able to trigger any of the AcadApplication events,
' you will first need to run this procedure.
' We could get the application from the ThisDocument object, but that
would
' require having a drawing open, so we grab it from the system.
Set ACADApp = GetObject(, "AutoCAD.Application")
FN = GetVariable("DWGNAME")
Call ACADApp_EndOpen(FN)
End Sub
Private Sub ACADApp_BeginQuit(Cancel As Boolean)
If DOCUMENTNAME = "" Then End
myitem.Subject = DOCUMENTNAME
myitem.StopTimer
myitem.Save
SALARYMANOPEN = False
End Sub
Private Sub ACADApp_EndOpen(ByVal FileName As String)
If SALARYMANOPEN = True Then
myitem.StopTimer
myitem.Save
Set myolapp = CreateObject("Outlook.Application")
Set myitem = myolapp.CreateItem(4)
myitem.Type = "AutoCAD"
myitem.StartTimer
DOCUMENTNAME = FileName
End Sub
A2Ki, SurvCad CES, Win98 se
Remove NO SPAM from my email address to email
Jonathan J. Baker
R&R Engineers-Surveyors, Inc.
Denver, Colorado
Replies (10)
Message 2 of 11
Jon,
What is the program doing? Does it give you an error
message? If so, what does the error message say?
Joe
Jon Baker wrote in message
news:380DC65513659BD7799874AE3C025BBF@in.WebX.maYIadrTaRb...
to
explanations
> Option Explicit
Event
> Examples
> Public FN
> Sub AcadStartup()
> used
generic
> object
events,
> would
> End Sub
> myitem.StopTimer
> myitem.Save
> End Sub
> myitem.StopTimer
> myitem.Save
> End If
> myitem.StartTimer
> End Sub
> Jonathan J. Baker
> Denver, Colorado
Message 3 of 11
well i am not getting any real errors...
i get this when first start acad:
Regenerating model.
Initializing VBA System...
Loading VBA startup file...
so i work for a while... save and close...
nothing is in the outlook journal. i went in the journal settings and
checked on AutoCAD drawing.
Jonathan J. Baker
Denver, Colorado
"Joe Sutphin" wrote in message
news:3066EAECFC9B7716ACAF608949C4E07D@in.WebX.maYIadrTaRb...
> Jon,
> Joe
it
> to
i
> explanations
info
> > Option Explicit
> Event
> > Examples
> > Public FN
> > Sub AcadStartup()
be
> > used
> generic
> > object
> events,
that
> > would
> > End Sub
> > myitem.StopTimer
> > myitem.Save
> > End Sub
> > myitem.StopTimer
> > myitem.Save
> > End If
> > myitem.StartTimer
> > End Sub
> > Jonathan J. Baker
> > Denver, Colorado
Message 4 of 11
Jon,
I suspect that what you are not doing is running the AcadStartup macro.
Do the following after you load the program.
Type -vbarun at the AutoCAD command prompt
Type acadstartup
For those who want an explaination, because the application is using
AcadApplication events they have to be initialized which is what the
AcadStartup macro is doing.
Joe Sutphin
Want a VBA Macro Recorder With Source Code???
Find out how at joesu@worldnet.att.net?subject=VBA_Macro_Recorder_Source
news:B809FC37AA3D380A4A286CDFAC78E4E7@in.WebX.maYIadrTaRb...
> Regenerating model.
> Jonathan J. Baker
> Denver, Colorado
> > Jon,
> > Joe
> it
> > to
site.
> i
> > explanations
> info
> > > Option Explicit
> > Event
> > > Examples
> > > Public FN
> > > Sub AcadStartup()
> be
> > > used
> > generic
> > > object
> > events,
> that
> > > would
> > > End Sub
> > > myitem.StopTimer
> > > myitem.Save
> > > End Sub
> > > myitem.StopTimer
> > > myitem.Save
> > > End If
> > > myitem.StartTimer
> > > End Sub
> > > Jonathan J. Baker
> > > Denver, Colorado
Message 5 of 11
-VBARUN
Command: Initializing VBA System...
Macro name: ACADSTARTUP Execution error
Jonathan J. Baker
Denver, Colorado
news:6808B010AE2CCF96A2CAD8E7B4BC989A@in.WebX.maYIadrTaRb...
> Jon,
> Type acadstartup
> Joe Sutphin
> > Regenerating model.
> > Jonathan J. Baker
> > Denver, Colorado
> > > Jon,
> > > Joe
get
> > it
> > > to
> site.
> > i
> > > explanations
> > info
> > > > Option Explicit
Application
> > > Event
> > > > Examples
> > > > Public FN
> > > > Sub AcadStartup()
will
> > be
> > > > used
> > > generic
> > > > object
> > > events,
> > that
> > > > would
> > > > End Sub
> > > > myitem.StopTimer
> > > > myitem.Save
> > > > End Sub
> > > > myitem.StopTimer
> > > > myitem.Save
> > > > End If
> > > > myitem.StartTimer
> > > > End Sub
> > > > Jonathan J. Baker
> > > > Denver, Colorado
Message 6 of 11
Are you should that you have the application loaded?
Type _vbaload at the AutoCAD command prompt
Select the filename from the Open VBA Project dialog box
Type -vbarun
Type acadstartup
Joe
news:5530649DE46CC862A3CA1995D653B492@in.WebX.maYIadrTaRb...
> -VBARUN
> Jonathan J. Baker
> Denver, Colorado
> > Jon,
> > Type acadstartup
> > Joe Sutphin
> > > Regenerating model.
> > > Jonathan J. Baker
> > > Denver, Colorado
> > > > Jon,
> > > > Joe
> get
> > > it
> > > > to
> > site.
> > > i
> > > > explanations
it
> > > info
> > > > > Option Explicit
> Application
> > > > Event
> > > > > Examples
> > > > > Public FN
> > > > > Sub AcadStartup()
> will
> > > be
> > > > > used
an
> > > > generic
> > > > > object
AcadApplication
> > > > events,
but
> > > that
> > > > > would
system.
> > > > > End Sub
> > > > > myitem.StopTimer
> > > > > myitem.Save
> > > > > End Sub
> > > > > myitem.StopTimer
> > > > > myitem.Save
> > > > > End If
> > > > > myitem.StartTimer
> > > > > End Sub
> > > > > Jonathan J. Baker
> > > > > Denver, Colorado
Message 7 of 11
yes i added it to my startup suite and i just did it like you said.. still:
Command: *Cancel*
Command: VBALOAD
Command: -VBARUN
Execution error
Command: *Cancel*
Jonathan J. Baker
Denver, Colorado
news:0C2B33D83B477DE400A47F05D956CC00@in.WebX.maYIadrTaRb...
> Type -vbarun
> Type acadstartup
> Joe
> > -VBARUN
> > Jonathan J. Baker
> > Denver, Colorado
> > > Jon,
macro.
> > > Type acadstartup
> > > Joe Sutphin
> > > Find out how at
> > > > Regenerating model.
and
> > > > Jonathan J. Baker
> > > > Denver, Colorado
> > > > > Jon,
> > > > > Joe
can
> > get
> > > > it
> > > > > to
web
> > > site.
> > > > i
> > > > > explanations
with
> it
> > > > info
> > > > > > Option Explicit
> > Application
> > > > > Event
> > > > > > Examples
> > > > > > Public FN
> > > > > > Sub AcadStartup()
which
> > will
> > > > be
> > > > > > used
intercept
> an
> > > > > generic
> > > > > > object
> AcadApplication
> > > > > events,
> but
> > > > that
> > > > > > would
> system.
> > > > > > End Sub
> > > > > > myitem.StopTimer
> > > > > > myitem.Save
> > > > > > End Sub
> > > > > > myitem.StopTimer
> > > > > > myitem.Save
> > > > > > End If
> > > > > > myitem.StartTimer
> > > > > > End Sub
> > > > > > Jonathan J. Baker
> > > > > > Denver, Colorado
Message 8 of 11
This declaration
' Use with Application Event Examples
must be in a class module. The most obvious place for
it would be the ThisDrawing module.
Joe Sutphin
news:4B637ABBC3639648BE16938789502AEB@in.WebX.maYIadrTaRb...
still:
> Command: *Cancel*
> Command: VBALOAD
> Command: -VBARUN
> Execution error
> Command: *Cancel*
> Jonathan J. Baker
> Denver, Colorado
> > Type -vbarun
> > Type acadstartup
> > Joe
> > > -VBARUN
> > > Jonathan J. Baker
> > > Denver, Colorado
> > > > Jon,
> macro.
> > > > Type acadstartup
> > > > Joe Sutphin
> > > > Find out how at
> > > > > Regenerating model.
> and
> > > > > Jonathan J. Baker
> > > > > Denver, Colorado
> > > > > > Jon,
> > > > > > Joe
> can
> > > get
> > > > > it
> > > > > > to
> web
> > > > site.
> > > > > i
me
> > > > > > explanations
> with
> > it
> > > > > info
> > > > > > > Option Explicit
> > > Application
> > > > > > Event
> > > > > > > Examples
> > > > > > > Public FN
> > > > > > > Sub AcadStartup()
> which
> > > will
> > > > > be
> > > > > > > used
> intercept
> > an
> > > > > > generic
> > > > > > > object
> > AcadApplication
> > > > > > events,
object,
> > but
> > > > > that
> > > > > > > would
> > system.
> > > > > > > End Sub
> > > > > > > myitem.StopTimer
> > > > > > > myitem.Save
> > > > > > > End Sub
> > > > > > > myitem.StopTimer
> > > > > > > myitem.Save
> > > > > > > End If
> > > > > > > myitem.StartTimer
> > > > > > > End Sub
> > > > > > > Jonathan J. Baker
> > > > > > > Denver, Colorado
Message 9 of 11
okay... ummmm how can i do that?
Jonathan J. Baker
Denver, Colorado
news:8915BA0CAAD372445C8856AB19751407@in.WebX.maYIadrTaRb...
> This declaration
> Joe Sutphin
> still:
> > Command: *Cancel*
> > Command: VBALOAD
> > Command: -VBARUN
> > Execution error
> > Command: *Cancel*
> > Jonathan J. Baker
> > Denver, Colorado
> > > Type -vbarun
> > > Type acadstartup
> > > Joe
> > > > -VBARUN
> > > > Jonathan J. Baker
> > > > Denver, Colorado
> > > > > Jon,
> > macro.
> > > > > Type acadstartup
using
the
> > > > > Joe Sutphin
> > > > > Find out how at
> > > > > > Regenerating model.
settings
> > and
> > > > > > Jonathan J. Baker
> > > > > > Denver, Colorado
> > > > > > > Jon,
> > > > > > > Joe
they
> > can
> > > > get
> > > > > > it
> > > > > > > to
www.autojournal.net
> > web
> > > > > site.
> > > > > > i
> me
> > > > > > > explanations
> > with
> > > it
> > > > > > info
> > > > > > > > Option Explicit
> > > > Application
> > > > > > > Event
> > > > > > > > Examples
> > > > > > > > Public FN
> > > > > > > > Sub AcadStartup()
> > which
> > > > will
> > > > > > be
> > > > > > > > used
> > intercept
> > > an
> > > > > > > generic
> > > > > > > > object
> > > AcadApplication
> > > > > > > events,
> object,
> > > but
> > > > > > that
> > > > > > > > would
> > > system.
> > > > > > > > End Sub
> > > > > > > > myitem.StopTimer
> > > > > > > > myitem.Save
> > > > > > > > End Sub
> > > > > > > > myitem.StopTimer
> > > > > > > > myitem.Save
> > > > > > > > End If
> > > > > > > > myitem.StartTimer
> > > > > > > > End Sub
> > > > > > > > Jonathan J. Baker
> > > > > > > > Denver, Colorado
Message 10 of 11
has anyone figured this out yet... please i beg you...
Jonathan J. Baker
Denver, Colorado
"Jon Baker" wrote in message
news:A6C849FCBB8F2797C4ACD2E611CC5C0B@in.WebX.maYIadrTaRb...
> Jonathan J. Baker
> Denver, Colorado
> > This declaration
> > Joe Sutphin
> > still:
> > > Command: *Cancel*
> > > Command: VBALOAD
> > > Command: -VBARUN
> > > Execution error
> > > Command: *Cancel*
> > > Jonathan J. Baker
> > > Denver, Colorado
> > > > Type -vbarun
> > > > Type acadstartup
> > > > Joe
> > > > > -VBARUN
> > > > > Jonathan J. Baker
> > > > > Denver, Colorado
> > > > > > Jon,
> > > macro.
> > > > > > Type acadstartup
> using
> the
> > > > > > Joe Sutphin
> > > > > > Find out how at
> > > > > > > Regenerating model.
> settings
> > > and
> > > > > > > Jonathan J. Baker
> > > > > > > Denver, Colorado
> > > > > > > > Jon,
> > > > > > > > Joe
> > > > > > > > Jon Baker wrote in
message
> they
> > > can
> > > > > get
> > > > > > > it
> > > > > > > > to
> www.autojournal.net
> > > web
> > > > > > site.
> > > > > > > i
give
> > me
> > > > > > > > explanations
anything
> > > with
> > > > it
> > > > > > > info
> > > > > > > > > Option Explicit
> > > > > Application
> > > > > > > > Event
> > > > > > > > > Examples
> > > > > > > > > Public FN
> > > > > > > > > Sub AcadStartup()
(ACADApp)
> > > which
> > > > > will
> > > > > > > be
> > > > > > > > > used
> > > intercept
> > > > an
> > > > > > > > generic
> > > > > > > > > object
> > > > AcadApplication
> > > > > > > > events,
> > object,
> > > > but
> > > > > > > that
> > > > > > > > > would
the
> > > > system.
> > > > > > > > > End Sub
> > > > > > > > > myitem.StopTimer
> > > > > > > > > myitem.Save
> > > > > > > > > End Sub
> > > > > > > > > myitem.StopTimer
> > > > > > > > > myitem.Save
> > > > > > > > > End If
> > > > > > > > > myitem.StartTimer
> > > > > > > > > End Sub
> > > > > > > > > Jonathan J. Baker
> > > > > > > > > Denver, Colorado
Message 11 of 11
Jon...I may be tripping over too much coffee but where do you get MyTime associated. I see it defined as an object but don't see anything else until it pushes you to Call ACADapp_EndOpen. You then use MyTime but that is before you Set MyOlApp and Set MyTime. Kind of confusing.
Good luck,
Bob Coward
CADS, Inc.
