Revit Architecture
Revit Architecture
andrea.pontiggia
Message 1 of 24 (6,894 Views)
Italian language pack for Revit 2013
6894 Views, 23 Replies
05-10-2012 03:49 AM
Hello, can you tell me when it's ready for the Italian language pack inserted in the version of Revit Building Design Suite Premium 2013? thanks
Andrea
john.lipp
Message 2 of 24 (6,818 Views)
Re: Italian language pack for Revit 2013
05-15-2012 09:49 AM in reply to: andrea.pontiggia
Dear andrea.pontiggia
You can find the language packs for Revit 2013 from the links below:
Revit Architecture 2013
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=19222370&linkID=19222558
Revit MEP 2013
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=19222482&linkID=19223913
Revit Structure 2013
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=19222489&linkID=19223921
Please let me know if you need further assistance.
Best regards,
John Lipp
Support Specialist
Product Support
New Member
spatialy
Message 3 of 24 (6,518 Views)
06-13-2012 04:14 AM in reply to: john.lipp
It's possible using other product languages as you tell?
please any workaround or how-to about this?
I intereresed in spanish translation but no have idea ho do this with languages packages of simple Revit architectural or Revit MEP
Thans and best regard
Yulian
New Member
paolo
Message 4 of 24 (6,482 Views)
06-16-2012 02:48 AM in reply to: spatialy
I'm trying to install the italian language pack for revit 2013 but I'm experincing the following issue: once I click over the EXE file (Autodesk_Revit_2013_Italian_LP_Win_32-64bit.exe) the unpack application shows me only "extract" (not "install"). After having uncompressed all the stuff, if I go into the unpacked dir I don't find any way to install the italian language pack (there is only setup.ini and not setup.exe).
As to other language packs I don't have the same issue (the EXE file shows me the "INSTALL" button).
How should I fix it?
andrea.pontiggia
Message 5 of 24 (6,331 Views)
06-27-2012 04:28 AM in reply to: paolo
I have the same problem Paolo.
What should I do to the language pack ita Revit 2013 included in Buiklding Design Suite?
Tanks Andrea
Andrea
Member
yaoqiangjian
Message 6 of 24 (5,172 Views)
09-23-2012 03:07 PM in reply to: andrea.pontiggia
Hi I have the same problem, I don,t know how to install the language pack,
Member
yaoqiangjian
Message 7 of 24 (5,170 Views)
09-23-2012 03:08 PM in reply to: paolo
Hi, have you fixed the language pack problem? cause i have the same problem.....
andrea.pontiggia
Message 8 of 24 (5,157 Views)
09-24-2012 12:21 AM in reply to: yaoqiangjian
I did the following:
-I installed the suite without Revit 2013;
-I downloaded from the site Autodesk Revit-ita;
-I installed Revit 2013 with serial suite.
Andrea
Employee
tony.michniewicz
Message 9 of 24 (5,093 Views)
09-25-2012 10:18 AM in reply to: andrea.pontiggia
Revit handles language packs differently than AutoCAD and they must be included as part of the initial installation.  Here are the steps to include a language pack in a Revit installation.
1. Download and extract the contents of the desired language pack.
2. Launch the Revit installer and accept the end user license agreement, which will bring you to the Product Information page.
3. Expand the Product Language drop-down list and select Add Language Pack.
4. In the resulting dialog, click the Browse button associated with the Revit product being installed.
5. Navigate to and select the appropriate MSI file from the extracted language pack content, then click Open.  As an example, here is the path to the MSI file for the French language pack for Revit Architecture on a 64-bit system: C:\Autodesk\Autodesk_Revit_Architecture_2013_French_LP_Win_32-64bit\x64\fr-FR\RAC2013\RAC2013LP.msi.
6. Click OK to dismiss this dialog.
7. Complete the remainder of the Revit installation.
Once the installation is complete, Revit will be configured using the selected language pack.
Tony Michniewicz
Autodesk Revit QA
Member
yaoqiangjian
Message 10 of 24 (5,079 Views)
09-25-2012 03:08 PM in reply to: tony.michniewicz
Hi, thanks for the reply, but it doesn't work. here pic. I downloaded the language pack Autodesk.REVIT 2013.jpg
