Solved by vanderloo5. Go to Solution.
Yes, i still can´t see the attachment. But, if you can see the xref'd elements in autocad can't you bind it and then link to revit? (i don't know autocad very well, so sorry if this is a stupid question)
I tried to reproduce the issue here but couldn’t (when I copied the file without the xref to a new folder the xref disappeared from the main dwg). Also don’t know how you can see the xref if they didn’t send it with the main file.
Gustavo
