I am working on a project in Revit 2012 that has a floor plan and a structural floor plan. When I pull up the project in 3D mode I see everything that I worked one. When I go to the structural floor plan I see everything as well, but when I go to the regular floor plan I see nothing at all. I tried zooming to fit, zoom all to fit, and other ways to zoom in. The only way I am able to see the floor plan is when I go to the Work Plan Viewer on the ribbon. Any advice? Thank you for your time.
It looks like you work in a Structural Template...
Try this:
With nothing selected in View, RC and from contextual menu choose :Apply Template ti Current View...Under NAMES..choose Architectural Plan.....
You can also with a selected wall ( in one of the Views that you seen) to have a look on Properties >Structural...check or uncheck this option as you want to have a structural or partition wall
Constantin Stroescu
Thank you for your help. It is strange because when I went in to try your suggestion the architectual floor plan was showing. I am not sure why sometimes it shows and sometimes it does not.
I am still having this issue. I went in and made sure that the view was architecture and not structural. I am not sure what is going on.
Great post (and a long thread) about 33 possible reasons why you can't see your stuff over at RevitForums.org....
http://www.revitforum.org/tutorials-tips-tricks/441-cant-see-view-heres-33-reasons.html
