I'm adding a few dimensions on my idw containing isometric views. All is perfect except for one dimension that does not want to go where I want it. Is there a trick to this? See attached the result I get and I marked in red what I want to achieve.
Thanks in advance,
Solved by constantin.stroescu. Go to Solution.
use Set Work Plane in order to place the dimensions on the Plane you want to:
Set > Work Plane > Pick a Plane - and Show to see this Plane....
Constantin Stroescu
